Backscatter problem
Started by Gwangi ·
Backscatter problem
  1. Hi all,
    I seem to be getting backscatter... What is the advice for placement and position of strobe for micro?
    THe picture below I place the strobes 12" above and 6" in front of the port pointing 90 degrees downward.
    I'm using a Fuji S2pro with Ikelite (gen 1) housing, 2 Ikelite 100 strobes...
    Any advices is very much appreciated.
    Regards
    KL Kwang
  2. Backscatter is not just about the positions of your strobes, but also how much water you are shooting through. The further you are from your subject the more chance you have of backscatter. The best way to get rid of backscatter is to get closer. If you used a 105mm lens for this shot, then try a 60mm.
  3. If the water has a certain amount of suspended matter in it then this will show if it is illuminated by the flashes regardless of their positioning. As Alex said try a shorter lens, OR you can try making the flash illumination as oblique as possible. For the 'left-over' backscatter that changing lenses or moving flashes doesn't deal with, I'd suggest editing it out in Photoshop or similar (many may disagree, but.....).
