Wet Filter for Sealux macro port question?
Started by Jettbritnell ·
  1. Hi
    Wondering if anyone on Wetpixel has used a wet diopter on a Sealux CD70 macro port? I'd also be interested in knowing what brand of wet diopter you are using.
    Jett
  2. Hi Jett,
    I don't use a Sealux, but can still offer some suggestions:
    1) Measure the diameter of your port. If it's anywhere from say 90mm to 115mm, you can find a Woody's diopter that works with your port. This gives roughly 30% magnification. You can check it out at: http://www.nexusamerica.com/ under "Accessories"
    2) You can also check out the MacroMate solution at http://www.backscatter.com/HostedStore.Las...f3cfbee847c5b3d
    It's much more expensive, but yields a 100% extra magnification (2:1 with a 60mm or 105mm lens).
    3) Seacam are also working on wet-attached diopter lenses which look really promising and may be compatible with your port, but these may not available for some time. You can find out more at http://wetpixel.com/i.php/full/seacam-wet-diopter/ or find out more by contacting your local rep: http://www.seacam.com/en/kontakt/kontakte.htm
    Good luck,
    Mat
  3. Hey...Thanks Mat. I appreciate you taking the time to respond.
    All the best, Jett
  4. All three are available now. I have moved this post to DSLRs where it shoudl get more attention.
