Woody's Diopter and Ikelite port #5502
Started by michelangelo ·
  1. Back again with another question. I hope you guys don't mind me abusing your collective wisdom.
    Has anybody tried a Woody's Diopter on Ikelites macro port 5502. According to my calculations I will need the 110mm diameter model for this port, could someone confirm this. Also is it usable with the Canons 60mm EFS Macro or dose the 60mm focus so closly that I will end up knocking out the subject with the port ?. Last part of the question can you pick these up in Singapore or only by mail order from Nexus USA.
    Thanks for any help.
  2. the CL100 is correct for Ikelite flat ports....60mm or 105mm....works great!
    Reef Photo
    Karl
    Edited by kdietz
  3. Woody's diopter fits even a Seacam macro port, which is about 115mm diameter, so 110mm should be no problem. The diopter comes with a separate rubber ring that you can use if your port diameter is smaller than the internal diameter of the diopter.
    If in doubt, just drop an email directly to Woody (info@NexusAmerica.com). He's very nice and replies fast.
    Mat
