D2x Settings
Started by cor ·
D2x Settings
  1. Hi all, for those with the D2x, any tips on specific D2x settings? Coming from the D100 im sure I can figure it out after a few dives, but maybe someone thinks a specific setting is a must?
    Regards,
    Cor
  2. Hi Cor,
    The only things I did was change the color mode to Adobe RGB III, and set the sharpening to +1 (it helps to evaluate the focus on the LCD). I also turned down the LCD brightness, it is so bright that you may think that underexposed images are correctly exposed if you don't look at the histogram. Another thing was that I couldn't see the number of remaining shots on the top LCD, so I changed the camera to display it in the back.
    That's all I can think of, all the other settings are personal preferences.
    Luiz
