weight belt for underwater camera?
Started by ID student ·
  1. Hi i've read suggestions on whether to get camera with positive buoyancy or negative buoyancy. Adding weight to camera to offset buoyancy was actually brought up. However i can't really find any weight belt to go with housing.
    pls advice or enlighten thanx
  2. What housing do you have?
    Some Ikelite housings come with a lead weight that you can add to the handles.
    Does your housing have a tripod mount? YOu could attach a lead to the housing to the tripod mount with a screw.
    Edited by acroporas
  3. Add a strobe, its will make your underwater set heavier and your wallet lighter :(
    As acroporas wrote, the best way to attached something to the housing is by the tripod mount.
