Multiple RAW files
Started by jcclink ·
Multiple RAW files
  1. How can I open multiple RAW files at the same time in separate windows like I do with JPEGs in PSCS? It helps in my editing process if I can rapidly jump back & forth between several pics of the same subject to check focus, etc. Thanks.
  2. Try this and see if this is close enough. In your image brousing program or (windows explorer) select all of your raw's. Then drag and drop them into photoshop window.
  3. Just tried your suggestion. Only the first file opened in the RAW Converter window. Worth the try thou. Would it be any different in PS/CS2?
    Edited by jcclink
  4. William's suggestion works fine on CS2. See attached image for a typical view. You can click on the thumbnails on the left of the window to alternate between the different images.
    Mat
