SB 105 sync cord in sea&sea housing
Started by imp ·
  1. Hi guys,
    Just wondering if the SB sync cord that fits the nikonos camera, could be use in a sea& sea housing. I have a set of SB105 set that use to fit my nikonos.wondering if i could conect to the sea n sea, since it has a nikonos mount? pls advised
  2. No problem, I have used an SB105 connected with a Nikonos cord to my Sea&Sea housing (for F100) many times.
    Luiz
  3. so i can actually use the sb105 sync cords with d70s sea&sea housing? just to confirm.. hehehe
  4. Yes... :( It will be the same as using a Sea&Sea TTL cord with a Sea&Sea strobe.
    If it doesn't work (I doubt), cover with tape the hotshoe pins 1 and 4 indicated in this diagram:
    http://wetpixel.com/i.php/full/nikon-d2x-h...ndrome-and-fix/
    The photo above is of a Seacam hotshoe, the Sea&Sea looks the same but you can't remove the pins. But try it first, it may work before covering the pins. Maybe sea&sea did this modification in the housing, I am not familiar use its digital housings.
    Edited by Rocha
