D70s, Sea&sea Housing, 18-70 kit lens.
Started by imp ·
  1. Hi guys,
    Thanks to Rocha on the posting about using the 18-70mm kit len, i would like to know, what kind of diopter is needed for that lens with a Sea&sea D70s Housing. Cos after reading all those post, i realised that its for ikelite housing. so any sea&sea owners with some updates
    Setup: D70s
    18-70mm kit lens
    Sea&sea Housing
    56401 wide domeport
    what diopter? or no diopter needed
    recomended is, 67mm B+W close up x4, is this rite?
    pls advised
    Edited by Rocha
  2. Sea&Sea recommends that this lens is to be used with a compact wide port L and compact macro base here:
    http://www.seaandsea.jp/products/chart_zoom.html
    But I think it should work behind the dome that you have with the proper extension ring. Subal recommends its fisheye port with a 20mm extension ring, so this is a start. But let's wait to hear from Sea&Sea users about it.
    Luiz
    Edited by Rocha
  3. Hi I Use it !!
    compact dome port with 40 extension ring & +4
    samples
    regards
    craig
    Edited by craig nelson
