strobe advice please
Started by steve-k ·
  1. im very new to underwater photography,
    that new in fact my housing is still in the post lol
    been looking at strobes and need a little help
    firstley, im a diving instructor and know quite a lot about (dry) photography, i have the canon 20-d, and should be recieving the ikelite housing in the next few days
    i was going to get the ikelite ds125 strobe to utalise the ttl
    what are the real benifits of running 2 strobes?
    would a ds-50 and ds-125 combo work?
    how would the ttl work in low light situations, or even on a night dive?
    are there any books you can recomend
  2. In short, the DS50 and DS125 combination does work, but is not the most flexible. The DS50 does not have built-in power settings and requires and external controller to change its intensity. This adds to the cost of the setup. Also, a number of situations require both strobes to have similar intensities, and the DS125 is quite a fair bit more powerful than the DS50.
    As for your other question, there are a number of advantages in having two strobes: you can cover more grounds on wide angles, you can soften shadows on macro and portraits, you have a spare in case of problem, etc.
    I can't comment about TTL, as I shoot only in manual, but I'm sure others will help you there.
    As for books, check out the Essential Guide to Digital Underwater Photography...
  3. thx for the advice, i have ordered the book
    i am (after further advice) going to get one 125 and just get used to the system on a 60mm befour adding another 125, and going wide
