Has anybody a idea how i can easily diffuse the light of my fokusing lamp to mind hot spot. Is it possible with a kind of sticker to put in front?
Light Diffuser for Focusing Lamp
Started by orlando_xxx ·
- 4Posts
- 4Replies
Crinkle/roll up up some "tin foil", then flatten it back out and insert over the reflector of the lamp. Trim the edges, replace the lens, and Viola!
HI Orlando!
I have sucessfuly used "Prinkel's" tops and other plastic tops from a wide range of consuner every day opjekts!
If it's too clear/dosen't diffuse enough just use some fine sandpaper so you can "adjust" it
So happy hunting...
NB: if you can't find one that fits over the lamp trie a flat pice inside! that's how i made my red filtered light for shy critters!!
:ninja:Hope you can use this info
Woops!
Forgot to ad that I hold my outside diffuser in plase with a moded neoprene beer cooler!
If everythine else fails Duck tape....
