Plans for focus light bracket
Started by acroporas ·
  1. Recently I purchased a UKE L2 dive light. Very small (only slightly larger than my middle finger) and a very bright (brighter than most 6 C-cell lights) though narrow beam.
    I think this would make a perfect focus light for macro. There bright beam is what you need for macro.
    So I have been working on a way to mount it.
    Narrow beam is OK for macro but aiming may be difficult so I want something that will make aiming easy. I found that aiming the focus lights on my DS-125's was too difficult. Thus I wanted something easier to aim.
    So the idea was something that will only allow the light to pivot in 1 dimension. The light will always be parallel to the port when you look from above, but when you look from the side it can pivot.
    I am very experienced at plumbing so PVC pipe is my preferred material choice. For me it is the easiest to work with so that is what I chose for my design.
    The attached image is not to scale. I am thinking that I would probably use 3/4" pvc.
    The 4-way fitting would not be glued in place to allow rotation.
    The light will fit relatively snugly inside a 3/4 fitting so all that would be needed to attach the light to the fitting would be a rubber band to make sure the light did not float away.
    Does anyone have any comments or suggestions (for this/similar design or for an other device all together) before I go buy the parts and give it a try.
    Edited by acroporas
