Large Lucite Light-what is it?
Started by Jim Payne ·
  1. I was given this 14" x 5" light with a plexiglass case, two large batteries wired together, a lid with a switch and cable leading to a reflector housing. The bulb is covered by a thick test tube of glass and seals with three o-rings. It was made by a company called The Underwater Connection out of Newport News. I have looked and can't find any reference to this light. I would like to get it working but have no markings on voltage, just the logo. Thanks for any info on this beast and parts.
    Jimpost-5578-1133810989_thumb.jpgpost-5578-1133811001_thumb.jpgpost-5578-1133811015_thumb.jpgpost-1-1108530710_thumb.jpg
  2. Someone on the Beginner Forum said this looked like an old Dive Rite light. I called them and it isn't their's but they may be able to help me. The batteries are 12v wired together giving 24v. I have found some batteries that look similar, are 12v, will fit when wired together. They differ in amp hours: anything from 3 to whatever (depending on how much I want to pay). The Dive Rite rep asked if it was a 50w bulb. No idea because I can't find any markings. I am NOT an electrician, so I am looking for advice on battery selection. Maybe you buy as much bang as you can afford? I am assuming that a 12 Ah SLA battery is going to give me more time than a 7.2. I don't know how or if that effects the bulb. I also need to find out about bulbs (size, plug dimensions, halogen, etc). It seems that to recharge all I will need is a good quality automatic trickle charger.
    Hope my questions are appropriate. I am dealing with something new to me and appreciate any info. That one hint I got has gotten me this far, so I think this is a worth while project. Just want to do it right.
    Many thanks,
    Jim
  3. I found the Interstate Batteries has the SLA batteries that will fit and can be wired in series. Not too expensive, either. I just need to decide how many amp hour (more amps, more $$$). The o-rings are ok, but I want to replace just in case. Ideas for good sources. I am also wondering about bulb wattage. I would love to hear from someone who has used this type of rig.
    Many thanks,
    Jim
