10.5mm or 16mm Nikkor - or equiv in Sigma
Started by freediver ·
  1. Ok - I thought I was set on the 10.5mm nikkor lens, but now am wondering if it will be TOO specialized to not really be used other than underwater...
    So I am wondering which lens to go with - I will be shooting as well above water and when I worked as a photojournalist, I used my 24mm lens along with my 85 extensively...
    The 18-70 that comes with the D70's basically fits that arena, but with the conversion factor, the wide end only comes in at around 27mm..
    But I want to be able to work with very wide underwater while freediving - I have heard going with the Nikkor 16FE or the Sigma 15 is an alternative. Having been a lens snob in the past, I have ALWAYS used OEM lenses when I was shooting as a pro, so I am apprehensive about going after market. How have the after market lenses faired in the new digital revolution?
    Any comments on either of these 2 lenses when shooting digital and shooting both above and underwater?
    Looks like next friday is the big day for spending money.. :huh:
    Edited by freediver
  2. That's easy! Get the Sigma 15mm AND the Nikkor 10.5 The sigma lens is 'cheap' enough that if you can afford a D70setup, you can afford the sigma lens...lol
  3. Cliff
    You need both lenses and I was on the same dilemma Nikon 16mm or Sigma 15mm but on the end I have decide to go with Nikon. Why?
    Becauce off:
    1. better glass
    2. Its Nikon
    3. I have buy it in Hong Kong with international Warranty for 50% of the price that i can get it in Sweden
    4 and most!!!! important. The Sigma 15mm is not working with my port.
    So before you deside check wich housing & wich port you whant to use.
    Lambis
