D200 TTL protocol ?
Started by shchae ·
D200 TTL protocol ?
  1. Hi,
    I was checking digideep site & found following in D-200 spec;
    Support TTL protocol: Nikon-TTL, D-TTL & i-TTL
    Is it true ? or just an error ??
    Sam
  2. Nop, only iTTL. From dpReview:
    • TTL: TTL flash control by 1,005-pixel RGB sensor Built-in Speedlight: i-TTL balanced fill-flash or standard i-TTL flash (spot metering or mode dial set to [M])SB-800 or 600: i-TTL balanced fill-flash for digital SLR and standard i-TTL flash for digital SLR
    • Auto aperture: Available with SB-800 with CPU lens
    • Non-TTL Auto: Available with Speedlights such as SB-800, 80DX, 28DX, 28, 27, and 22s
    • Range-priority manual; available with SB-800
    http://www.dpreview.com/articles/nikond200/page2.asp
  3. Is the I TTL the same protocol like D70s or D2X becauce Nikon like to play with the I TTL protocols
    Heinrich adapters have show this to me...
    Lambis
