Nikon Capture 4.4.0
Started by Rocha ·
Nikon Capture 4.4.0
  1. Nikon has released version 4.4.0 of Nikon Capture, available here:
    Nikon Capture 4.4.0 for Windows (from Nikon Europe)
    Nikon Capture 4.4.1 for Mac (from Nikon Asia, you may need to download from the same region as your previous version)
    What is this update?
    This software updates Nikon Capture versions 4.2-4.3.2 to version 4.4.0. Any version of Nikon Capture 4 from version 4.2.0 to 4.3.2 must be installed before proceeding with this update. If you are using Nikon Capture 4 version 4.1.3 or earlier, please upgrade to version 4.2.0 before proceeding with this update.
    If Nikon Capture version 4.4.0 is to be used in combination with Nikon View, please be sure that you are using Nikon View version 6.2.7 for full compatibility of files and most functions.
    Improvements:
    - Support for D200 RAW images has been added.
    - A B&W (black-and-white) option has been added to the Color Mode item in the Advanced RAW tool palette.
    - Improvements to the method used to reproduce tones in highlight areas, preventing a loss of detail when Exp Comp is set to a negative value. (Does not apply to RAW images captured with the D1 or COOLPIX-series cameras.)
    Images edited using the Exp Comp with a negative value with Nikon Capture 4 version 4.3.2 and earlier are opened in Nikon Capture 4 Ver. 4.4.0 or later, the results of highlights may differ.
    Issues addressed with Nikon Capture 4 version 4.4.1
    Nikon Capture Editor
    - An issue that caused a Type 3 error to occur and Nikon Capture 4 to quit unexpectedly when attempting to print from Nikon Capture 4 Ver. 4.4.0 has been addressed. (Mac OS 9 only)
    Edited by Rocha
