1st dive w/ 10.5mm
Started by gianster ·
1st dive w/ 10.5mm
  1. A couple of shots with the 10.5mm at West Caicos for the 1st time. What do you think?
  2. I like #2 with the diver on the background. The others lack a clear subject on the foreground. What I do is try to find a big seafan or sponge to put in the foreground, and the diver in the background always works.
    Anyways, those are great to be your first shots with it. Nice that your fins or the strobes didn't appear in the photos.
    Luiz
  3. I think #1 is nice with the divers hanging on the deco bar. That pic shows the true value of the 10.5 by having a nice foreground main subject and then a vast panorama negative space with a boat and decompressing divers.
    Nice work
    Joe
  4. Look pretty good to me, as Luiz said, no strobe flare in the shots so you did well. Also looks like you got close to your subject and that is key, keep it up
  5. Number 1 is a good try but needs a diver in the near background, the ones by the boat are just too far. The second is your best pic but lacks a little impact on the main subject but I still like it. The third is really a throw away. Way to hot, need a couple stops down, everything is too centered and the bottom divers legs are cut off ...so ace that one. Great job though with this lens for the first time and I give this critique on a high level as the shots are good. In a year or two you will laugh at these compared to what you will have down the road. You are oviously reading and doing many of the basics correctly, shooting up, getting your subjects and backgrounds together. Work on finding good subjects, ie colorful or large items if no fish around. Editing wise avoid keeping pics like number 3 with a blown out surface, diver falling out of the frame etc. Keep at it.
  6. They are a great effort for first time out with this lens. It is not an easy lens to use to begin with. I'm on dial up so I only looked at the 1st one large. You are putting the image together pretty well. You need to concentrate on lighting the foreground more evenly. Think about moving your strobe to full illuminate the subject.
    Have a look at Espen Rekdal's website:
    http://www.espenrekdal.com/
    His fisheye lighting is fantastic. A great place for inspiration.
