is it possible to set WB with the filter?
Started by diver_neil ·
  1. hello group!
    was reviewing the topics posted here regarding setting the white balance, can i set the white balance with white slate with a filter attached so i can get good results when i change depths? thanks in advanced.
  2. Neil,
    The 7070 has a custom white balance option and you can use a white slate , gray card or even the palm of your hand to set it for the depth you are at. If in an area with a sandy bottom, I generally take a picture of the sand and use that shot to set the white balance off of. Keep in mind that if you change your depth by a few feet, you will want to take another shot to reset the white balance. Keep the filter on while adjusting the WB.
    Hope this helps.
    Edited by dmoss
  3. hi david! thanks for the reply. as your suggestion i will use the custom setup for the wb on the c-7070, need to review the manual again. again, thanks and more power to you.
    neil
