Beuchat VX100 Complete Setup with Octo
Started by Sloss ·
  1. Hi Everyone,
    I had this set up listed about 6 months ago but just dropped the price! I have a complete brand new regulator setup by Beuchat with a DIN connection. It is all in the original box and wrapping and is BRAND NEW, NEVER USED! I already have 5 setups I use for work and have no need for this one. The whole setup if you do the research is around $650 USD if not more. If you are interested, the package can be yours for $350USD! It is a steal at this price. You will have to pay for shipping though. If you are interested, send a message to me here or contact me at doug@oceanmagicproductions.com :(
    Thanks for looking!
    Doug
    Details
    Beuchat VX 100
    1st stage
    • New " Velvet Chrome " surface treatment combining strength
    with style.
    • Balanced diaphragm 1st stage.
    • Integrated anti-freeze system. (BEUCHAT patent).
    • 4 x 3/8’’ Low Pressure ports on a 360° rotating turret.
    • 2 x 7/16’’ High Pressure ports.
    • Large bore "Super Flow" hose.
    • New Ergonomic Elliptic Yoke for reduced weight.
    • 3300 PSI (230 bars) ‘A’ clamp or 3300 / 4300 PSI (230 / 300
    bars) DIN connector. Note: This first stage is a DIN connection only
    2nd stage
    • Balanced 2nd stage with numerous innovations.
    • Manually adjustable VENTURI control.
    • Sensitivity regulation by side control knob.
    • Larger exhaust valve.
    • Exhaust deflector with interior channel to control the air
    flow and deflect bubbles away from the face.
    VS octopus with bright neon yellow cover for high visibility.
    Equipped with a 39†Superflow hose for easy access. Features
    diaphragm deflector for reduceed free-flow. Calibrated for a broad
    range of supply pressures.
    Pressure Gauge 230Bar
    Edited by Sloss
  2. Hi Everyone,
    Just wanted to bump this great deal back in to existence. I have just lowered the price. It really is a great deal.
    Doug
