Best CRV3 for SP-350
Started by domino22 ·
  1. My SP-350 will arrive Monday. After reading all the posts I guess I need to order some rechargable CRV3 batterys? Which ones are the best to buy any thoughts please. Thanks
  2. I can't vouch for all of them, because I've only used one, but here's what I've found out. I got my RCRV-3 and charger kit at Radioshack. I'm not thrilled with the charger, as the battery seems to fit a little loose and gives it false readings, but once fully charged it seems to run on for a long time. I've read posts elsewhere that swore by Moby's (http://www.thomasdistributing.com/mpc-c301.htm). Someone claimed to have 500 shots on one. I've also had really good luck with my other cameras with SterlingTek. I didn't get theirs because I was in a hurry, and because the nominal capacity in their description seemed comparatively low. Their quality is really good, though. I've had a couple for my Sony for about 3 years and they're going strong and way better than the Sony originals. Also they're really cheap at $19.95 for the charger and $9.95 for the batteries. Maybe someone else can give you more accurate numbers.
