Aquatica D100 help
Started by Photobeat ·
Aquatica D100 help
  1. Looks like it will be an Aquatica housing for me as I sell of my Nikonos stuff. Anyone use the 17-55mmDX lens with Aquatica? If so are you what extension port do you use, are you using a diopter and does the 10.5mm dx zoom gear work with it?
    - If responding what legnth of strobe arm combo do you like with W.A ?
    Aquatica has done a setup with this lens yet, they gave me the theory of what should work but I am hoping someone has tried. Thanks so much
  2. I use the 10.5 with Aquatica. I usually use 14 inch arms. And the same with the 12-24 and the same with my NikV and 15mm....No problems
    Not sure about the 17-55.
    Perhaps send a PM to Jean Bruneau who is a member here on the site, he can probably figure out what combination of extension and gear you need for that lens
  3. Thanks Mike - I am buying Jeans rig actually. He is kind of digging through his stuff and putting things together for me. Hoping to find someone that actually used the 17-55dx with and without diopters etc. but it may be unlikely as this lens is fairly new regarding U.W. setups at least.
  4. Actually i believe Daveph uses it. Not sure about his housing....
    Hopefully he will see this thread, if not, go for the PM
