Hi OK it arrived yesterday my SP-350 I am sitting here tonight playing with it. I saved the post to keep the screen from going black/dark. Ok off topic heres what I want to know is why when I take a photo it does not appear on the screen like my 5050 so I can delete? You know take photo look at it and keep or delete. When I go to the "green triangle " for play back and try to delete it says quick print hook to computer- yes I have not read the book yet - you guys faster than I can read. Thanks
- 5Posts
- 5Replies
sp-350
Ok sorry started to read the book found out my problem operator error!! I will finish reading the ops manual before I bother you folks again. I SORRY.
Don't worry too much Domino....I searched the manual high and low for that blackened screen issue. There was even a guy on here who called Olympus Tech Support and they didn't have the answer. Thank God and Eric for Wet Pixel. BTW...I just called on the waterproof housing to find out the diameter of the threads in the barrel. No one could answer the question. So if you have questions...fire away.
Does this help with the thread size question?
http://www.digitaldiver.net/yabbse/index.p...=16418;start=15
What's the latest with the battery issue? Has the RCR-V3 fixed the problem?
Thanks, the WA link helped immensely.
the battery issue is basically two fold. 2500mah batteries should get you through 1G card with no problem. However the battery gauge will almost always reside in red and will begin to blink well before you get to the end of the card. With the V3s there seemed to be a problem with replacing a battery that was low with a fresh one. The camera didn't seem to acknowledge the fresh battery and turned off. Once powered is cycled and battery is removed and reinserted ... worked fine. I've not personally encountered the V3 issue since I've been using the AA rechargeables and getting enough out of them that I'm satisfied. I ran 2.5 512MB cards through one set in a quasi-test the other day. Mostly RAW was shot on the first card with a mixture of JPEG and RAW on the 2nd. Followed by 25 RAW on the 3rd card. I shot these photos with the internal flash going. I used the camera battery to reformat the cards before each load. Personally, I'm happy with that and won't switch to the RCR-V3 batteries. Later,
