New Tokina 12-24, is there an Ike Port?
Started by rj-diver ·
  1. Anyone know if the new Tokina AT-X124 Pro DX 12-24mm f/4 will work with any of the Ike ports for its D70 housing?
    Rich
  2. Yes, it will work behind the new 8" dome, or the #5503.50 6" dome.
    Will most likely require the special wide diameter zoom clamp. part #5509.28
  3. Thanks for the speedy response Will.
    Regards
    Rich
  4. The molded body taper of a #5503.50 dome port will not accept the 12-24 Tokina unless we machine the inside diameter. This is now available as #5503.51 @ $200.
  5. Ike thanks for the update, I presume as it has a part number it can be ordered direct through your distributors?
    Is the zoom clamp Will suggested (#5509.28) be the correct part also?
    Regards
    Rich
  6. yes and yes............
