iTTL converter
Started by sharky1961 ·
iTTL converter
  1. Hello,
    has anybody used the Mathias Heinrichs iTTL converter with the nikon d70 or d2x?
    Are you satisfied with the results?
    Are you able to use 6 powersettings (deliverd by the converter) in manual mode?
    Wich strobe do you use with ´the converter?
    Rob
  2. My converter arrived last friday. I did not have time to figure out how to install it yet...
    Check "How to use 100A with D70?" thread for some more info about converter.
  3. We have installed several d7o units, and they all work very well.
    Access to the Manual control modes depends on yoru camera's ability to change flash exposure compensation. Most housings don't access this function, making it impossible to use that feature. You can, however, set the manual outputs on the flash.
    The jury is still out on the d2x converter, I've only done one installation with Inon D-2000w strobes, and it requries a lot of exposure compensation.
    I would enourage having someone who knows what they are doing install this for you, as soldering those teeny tiny wires isn't much fun, and replacing melted bits gets expensive. In the US, my company offers the retrofits, as does Underwater Photo Tech.
