Those of you with Seacam housings...
Started by segal3 ·
  1. Would it be possible for any of you with Seacam housings to take a few photos of the (inside and outside) of the back as the viewfinder is assembled/removed from the back?
    I would greatly appreciate it. PM is fine as well.
    Edited by segal3
  2. sorry matt, gear is all packed as i am leaving tomorrow, if no one else can provide in the mean time i will try and do while in lembeh and post some photos then...
    one key thing is:never forget the clips (not sure if that is the right name for that circular item) on the inside of the housing that secures the viewfinder...
  3. See if this helps:
    Seacam Viewfinder Change Out
    Notes in:
    #4 Use one finder of one hand to hold the delrin ring in place, with the other hand use a finger to pry the other half of the delrin ring out of its grove.
    #9 When putting the viewfinder back make sure it is fully seated against the housing. This will ensure the delrin snap ring gets into the grove in #10.
    Keith
  4. Matt
    what are you trying to make now ?
  5. I think it is a "Seacam-a-ikelite"
    Ikelite front half of housing w/ Seacam back half....best of both worlds :D
