My 8080C locked up! Here's what happened. I turned on the camera to check a few things. In a short time it wouldn't do anything; no menu selection, no zoom, and I could not turn it off. I let it sit and thought maybe after a while it might go to sleep. It did not. After about a half hour it was still on and non responsive so I removed the battery and recharaged it to full. I also put in another flash card previously formated in the camera. I put the battery back in and tunred on the camera. Same thing; camera comes on viewing screen is on but no functionality. Has anybody seen this before? My camera is a little over a year old and I do have the latest firmware installed.
Sometimes this can happen with electronics if a button is continually being depressed. I would suggest checking each button. If you can't find a stuck button a good slap start (I'm serious) will often do the trick.
You did the first thing recommended. Take out the battery and wait 5 minutes or so. That will cure a lot of "lock ups". I would try it a few more times. Maybe even another flash card.
I had a similar lockup on my C5050. It turns out it was due to an incorrectly formatted 2GB CF card. The strange thing about it was that the card would work fine for a while and then the camera would would freeze. The camera was not able to reformat this card, nor was my PC. The thing that fixed it was to format the card in another camera, and then reformat it in the C5050. After that it worked perfectly. I don't know if your problem is related, but the halmark was that the camera would work fine with any card other than the bad one. Since your problem happens on two different cards, it is probably different.
I had a similar experience with my SP350. Taking out the battery and replacing it solved it the first time. The second time it had to do with a power loss during card reading. I ended up having to do the card reformat function in the menu, which was available. It sounds like yours is beyond that. Hopefully the button thing will check out.
