Epoque DS150 will not fire
Started by xberg ·
  1. Hi,
    I own the Epoque DS150 strobe. After about 10 dives it stopped firing - it still was charging correctly, but simply was not firing when my digicam's strobe fired. At first it only fired at the very lowest setting (GN3), but then not at all.
    I had it changed for another DS150.
    That one worked fine for another 5 dives and then the same problem happened again - but this time worse, at it simply does not fire at all, even at GN3.
    I don't believe it has ever flooded - the battery compartment looks super dry.
    I can't change it again - do you know of anywhere in Europe where I could service the strobe? Otherwise any recommendation for a cheap - and RELIABLE strobe?
    thanks!
  2. Hi,
    sorry to hear about your trouble. Just for confirmation: Both strobes didn't fire at all anymore? Not just a sync problem with preflash ignore settings?
    What camera do you use?
    Julian
  3. Julian,
    I don't use both strobes at the same time :) I first had the problem with a strobe, then changed it. After 10 dives I had the same problem with the second strobe. Both strobes were new.
    I use the Canon S50 - a splendid digicam with full maual controls, incl. pre-flash or not and 1st or 2nd curtain sync.
    Anyway the problem does not come from the camera as my second strobe does not fire at all anymore...
    Looking into another brand right now - will post my query in minutes.
    Thanks!
