L&M 2.5" monitor probs ??
Started by DeanB ·
  1. Hi all,
    Anybody else own the L&M 2.5" matrix monitor.
    After 2-3 weeks waiting for a new cable (from the housing to the monitor) I jumped for joy as it came through the post from my L&M dealer.. Attaching said device I found I still had no picture.
    I had previously found a fault in the old cable (shorting somewhere inside) and thought this was the problem. Obviously not.
    I have tried recharging the battery blah de blah..
    Anyone had the same problems. Is it going to cost me the earth.
    One thing after the fooking other.
    Dive safe
    DeanB
  2. I've had similar problems in the past, and it was all due to corrosion on the wet connect pins and receptacles. First clean the corrosion with electrical contact cleaner, or in worse cases, very fine sandpaper. When clean and dry, apply dielectric grease (silicone o-ring grease works great) to the pins, and insert repeatedly into the receptacles. Then wipe off excess grease. This will give you excellent electrical contact and prevent future corrosion. Also do this on the wet connects for your lights, and you'll probably get longer burn time, and more reliable lights.
  3. worth a try
    Cheers Dan...
    Dive safe
    DeanB
  4. Hi, i have a L&M 2.5" matrix monitor with no battery inside but powered by camera (TRV950). Could i use it also with FX1 ora A1e? Or i must use the new compact monitor with receargeable battery inside?
    Thank you for help :-)
    ERIK
  5. Hi Erik,
    I have the self-powered monitor but I do not know if it will work with the A1 as my monitor is being fixed. As soon as I get it back I'll tell you. Or you could try e-mailing F.E.P the L&M service centre here in the U.K:
    steve@fep.co.uk
    Good luck
    Dive safe
    DeanB
  6. Thank you, i receive now from L&M answer to my question:
    for Bluefin HD on ly self powerd monitor will works :-(.
    I will must change my monitor.
    Thank you
    ERIK
