shooting manual strobe
Started by sharky1961 ·
  1. hello,
    I am going to Lembeh in a few weeks and I will have to start shooting manual strobesettings. I have the nikon d200 and 2x Inon Z220 and 2x Sea&Sea Ys120 strobes.
    I will be shooting makro with the 60mm and 105mm and the 105mm with the 2x teleconverter.
    what is the best way to start with manual shooting ( I will use f-stops of 16 through 32)?
    Is there some golden rule for shooting makro??
    can I shoot aperture priority or do I have to shoot manual camerasettings??
    Until now I was shooting filmslides with TTL.
    I hope that someone can help me starting so that I don't have to figure it out myself in my holidays.
    BTW I will be shooting in a Sealux housing, they promised me to have it ready to ship in the 1st week of March :)
    Rob
  2. HI Rob
    Firstly
    Your thinking along the correct liine with your Aperture settings but F32 i dont think is going to be much use.
    I basically use upto F22 but mostly around F10-F16 for Max depth of field.
    Shooting A mode is not the best thing to do.
    When the nikon camera is placed into a mode other than M it will always try and balance your exposure or give you what it thinks is a correct exposure.
    now due to the fact that you might be using a 2 pin wired housing the camera wont even know that you have a flash present on you system so the balanced fill flash function will not work.
    The easiest way with maco is simply to preset using M mode. i tend to use F13 1/125 to start with and go with it from there using my strobes as the main light to paint the picture.
    Think about what the camera would do if you try using A mode, setting F13 @ iso 100 will give you about 1/15 or less underwater because the camera is giving you an exposure for what you are pointing it at and not knowing that you have 2x flash guns to provide the light for this shot.
    Hand holding a 105mm at 1/15 is only a recipe for BLURRED camera shaken images.
    use M on your camera and if you wish to adjust the background exposure of you shot you can reduce your shutter speed until you getting the desired effect, you can use the aperture a litte but remember that using aperture to control you background with do 2x things
    1x reduce your Depth of Field
    2x adjust the power of you flash
    your using inon guns so there is lots of settings for power adjustment, so you can drop a stop or two on aperture but watch the DOF .
    As for you using the 2x on a 105mm,,, remember you will get a 2 stop light loss, and an eqiv focal length of 300mm....!!! you have got to hand hold that, the age old rule of Shutter speed = Focal length of lens needs running through your head when using this combo.
    to be honest about it your better off using a wet dioptre or a close up filter, you will get no light loss then
    its no use shooting 1/60sec @ 300mm, you'll just get SHAKE.
    your DOF using the 2x will be very very shallow, so you'll try and use a very narrow aperture to increase the DOF, but you have a 2 stop light loss so you going to need to be VERY VERY close with those strobes to punch in light to make the shot when that 2x tele is attached
    when i used my 60mm with a 2x TC i found that using F10 to F8 often gave me the lighting result i was looking for but the DOF was extremely shallow.
    with all that then..
    use MANUAL mode on the camera
    Aperture and strobe setting to control the exposure of your subject
    Shutter speed to address the background exposure of your shot and to compensate for SHAKE.
    happy shooting
    craig
  3. To give you the short answer. Nearly all macro shots are taken from the same distance, give or take a bit. And therefore most require a pretty similar exposure.
    Start with your strobes on 1/2 power and the aperture on F22. And adjust as required You will be amazed how little things need adjusting.
    Kudos to Sealux for having the housing ready for you.
  4. Hi Rob,
    I will be in lembeh (Lembeh Resort) from the 6th of march to the 8th. I was wondering if by any chance you would be there. I have been thinking about buying the D200 and was waiting for the first UW reports. I would love to see your housing and meet another wetpixeller. Let me know if you are.
    Sylvie
  5. Hi Silvie,
    I will be there from 1 April-14 April and will be staying in the diverslodge Lembeh.
    So I will not see you.
    I can sent you some pictures of the housing as soon as I get it.
    have a nice holiday
    Rob
  6. Hi Rob,
    Yes, please do post some pictures of the housing, as I'm sure I'm not the only one interested. I'm a bit jealous but I did not want to rush into buying a setup. I will probably order the D200 when I come back, get use to it then order a housing later this summer. I was on a trip with Milan (sealux owner) last year in Komodo so I'm curious to see the housing. Just being in the States, I'm not sure that I should go with an european builder (just afraid that it might not be the easiest thing if I need to do some adjustement to the housing). Having said that, I'm not far from Fedex central location and I get stuff from Europe overnight so it might not really be a problem except potentially customs if not handle properly. I would hate to pay taxes everytime !!!!!
    Can't wait to see your pictures. Could you take a few sunburst pictures too, just to see what the camera can do and if the banding problem is a problem at all for that.
    Thank you very much
    Sylvie
