Nikkor 17-55 and Subal
Started by Rocha ·
  1. Hi all,
    Finally got back from Africa (well, almost, I am at Newark waiting for my connecting flight to Honolulu). Well, as I promised I am posting some test shots of the 17-55 and D2x with a Subal housing. The lens is amazing, extremely fast and very, I mean very sharp underwater. I used it with a +2 diopter, 60mm extension ring and Subal fisheye port, and the combination worked great. Here are two samples, one at 17mm and another at 55. Sorry for the lack of creativity on the shots, but this was my first time using it and I just wanted to test it.
    I hope this helps, and I can post more shots if you want. Oh, there was almost no post-processing. All I did was auto-levels. No sharpening.
    Luiz
    Edited by Rocha
  2. Here are two more samples.
  3. Hi Luiz,
    I used this lens for the first time last month - Subal - 70mm Ext +2 dioptre and Fisheye Port.
    Attached are a couple of images - no RAW or PS processing.
    17mm and 17mm at 100% crop
    regards
    ron
  4. now at 55mm
    I like this lens
    regards
    ron
  5. I was wondering if you guys tried any without the diopter or what what the reason to go with the diopter was in the first place (reccomendation or actual testing). Also if any one knows I would be interested in the dome curve radius of the subal port.
  6. I used the +2 because the Subal Dealer recommended it - will try without the dioptre next trip.
    Sorry don't know the radius.
    regards
    ron
  7. Here is one thats had a little work
