Which Strobe?
Started by IMSushi ·
Which Strobe?
  1. I've got a Sony P10 in an MPK-PHA housing. After I find the tray and arms I want, the next obvious piece is the strobe itself. I have heard some people say that a manual strobe is the way to go so you can get the precise flash strength? (I don't know the term) Or, should I stick with some of the newer ones that automatically sense what brightness I need for a particular shot?
  2. I used to have the same equipment... Slave sensor is the way to go for you, you can try an ikelite ds-125 with slave sensor for 800 US$.
  3. Yes, Felix, you know, I've looked at the Ikelight strobes and the extra slave sensor that is required seems a little over kill. Won't something like S&S YS90 with an internal, built in, sensor do the same thing?
    Then, what about an external dial to adjust flash intensity? Which is the ds-125?
