Batch Changing of IPTC Values
Started by Simon K. ·
  1. Hi I have just seen, that in the second D60 I bought used as Backup Camera the User Name was still set to the Previous Owner and all Pictures have this name still as IPTC Author Field.
    Is there a programm that can change this in batch bode for whole directory trees incl. Jpeg, PSD, TIF and CRW files?
    Simon
  2. You can record an action in Photoshop using the 'file info' to enter the values you want to the Mata-data fields, and then run this action on the whole directory.
    If you use Bridge you can select all the files you want selective and run the same action on them also.
