Macro Lens in Oly???
Started by rodriguezfelix ·
  1. Oly C-8080 have a macro lens of 1.5 X with an adapter or something... I know that PT-023 have a WA port (lousy as i heard...) but in the regular port, fit the macro lens??? or I need to get the WA port??? (please don´t say I need to get another camera.... I know that for sure...)
  2. Felix,
    If the lens is not an underwater lens...ie it connects directly to your camera then it probably won't fit in the standard port...especially if you're using an OLY Housing. If its an OLY lens, they'll have a port for it to go with the PT-023 Housing.
    If its a wet, conversion lens by another manufacturer (Inon, Epoque, or Sea&Sea etc)that mounts to your housing then you don't need a port for it. The adapter places the lens in the appropriate position and you can use it that way.
    later,
    Gary
