Ikelite 100A substrobe on 20D
Started by xtremediver ·
  1. :angry: Am I assuming correctly that I can still use my Ikelite 100A with the Canon 20D in an Ikelite housing if I only use it on manual? What about the Substrobe 50? What sync cord would I need to use, the older version or the new "blue" ring version.?
  2. I think you can. It works with my D70 in manual mode.
    I am getting a converter from www.heinrichsweikamp.net to be able to control it by adjusting flash compensation on camera.
    Check if you can get one for Canon.
    Andrzej
  3. Hi Guys,
    I don't think those flashes are capable of putting out the high speed preflashes required for digital TTL.
    They will work in manual though, if you use a dual cord set up for manual use. This means covering all the pins on the hotshoe except the center pin. I have done this using a piece of electrical tape. That is the "fire" pin and the ground contact is the metal lip of the hotshoe.
  4. The sync cord to which Luiz refers has a Nikonos connector for use with non-Ikelite housings. Standard Ikelite sync cord should be fine............
