Is there any disadvantage to using a Ike 8" dome for the lens other than Macro Lens.
My thinking was to get a 8" and use it for Nike 18-70, Sigma 15FE, and other lens I will get...( The 8" is not the recomended dome to use with the 18-70 as per the Ike Port list)
That way I will only be packing 1 Dome and another Dome Body to fit the other lens
Thanks Geo
You will need a flat port for the macro lens. The 8'' dome is only recommended for wide angle lenses (10.5, 15, 16, etc). I don't think the 18-70 can be used with the same 8'' dome as the 15, the extensions are different and as far as I know you can't change them on Ikelite ports.
P.S.: I am moving this topic to a more appropriate area, SLRs.
The port list says you can use it and you can change the extentions on the 8" #5510.81 port ....My question was is there any disadvantage to using the 8" on the 18- 70 as opposed to using the 6" dome#5503.55
If it works as good as the 6", I can buy the 8" and use it for my Sigma 15 with a different extention and I will only be packing 1 dome and the extentions rather than packing 2 seperate and complete ports
Geo
From looking at the chart the 8" is good for a lot of other lens also
Maybe the Ike man can awnser this one
I plan on using the 8" port with various length stalks for my 10.5, 15, 12-24 and 17-35.
IMHO, the 8" dome will be better for the 18-70. I have already used it with the 12-24 and the 15 and can say that I'm getting sharper corners than before.
Karl
That's great news. I didn't know you could change extension rings in the Ikelite system, it is great that now they are adopting this system. It certainly saves a lot of space in the luggage.
