Which Ikelite port for Sigma 150mm macro
Started by petr ·
  1. Hey Guys,
    did you try to use the Sigma 150mm 2,8EX APO macro lens? Which Ike port do you use with this lens?
    Petr
  2. Yes I use that lens in Ikelite housing.
    It requires the longest flat port. Part # 5505.58
    It is a close fit both in length and width. There is just barely enough room to install a diopter. The focus limiter switch may rub the side of the port so be very carefull that you do not accidentally change the setting when mounting the port. You have to mount the port last (still being carfull) to avoid this from happening.
    I will warn you that this lens is amazingly difficult to use on a crop-factor camera though a great lens and IMO worth it.
    Edited by acroporas
  3. As William so aptly puts it...
    This lens once magnified to an equivalent 225mm on Nikon dSLR or 240mm on a Canon dSLR cropped sensor camera willl try your patience. Adding a diopter to increase magnification even more will make this a real challenge!
    You may want to consider a 100 or 105mm lens (Not sure if you are shooting Canon or Nikon) and adding an external magnifier diopter on hte outside of the port.
    But if super small tele-macro images is what you'r after, the 150mm Sigma should do the job....
    YMMV
    dhaas
  4. Thanks guys for the replies. Well, frend of mine bought that lens and he would like to use it UW. He uses Nikon. He did the decision to buy the 150mm macro lens....so now he wants to use it.....
    Personaly I would use the 105mm but.......
    Thanks again.
    Petr
