What does the validity of topside lens testing mean to underwater use? For instance, if you find by testing above water that a given 16mm to 35mm zoom wide angle lens has awesome performance by all the usual standards, does that automatically mean that it will perform equally well underwater? And if it doesn't is it simply do to a lens/port mismatch that can be corrected with enough experimenting with various configurations? Does the same hold true for macro lens? If possible, please constrain the discussion to lens that are optimal and typically used underwater, such as fisheye's, 10mm to 40mm, both primes and zooms, and 50,60,and 100mm macros. All opinions welcome!
imasleeper
