Nikon D70+18-70 lens for Macro
Started by clarkedje ·
  1. I have recently upgraded to a Nikon D70 in an Ikelite housing from my old Sea&Sea DX3000, though the only viable lens I have is the 18-70 with a Dome port. Is this lens only effective for wide angle shots or can it also be used for macro?
    Any help would be much appreciated
    Dom
  2. Anyone?
  3. It's a fine lens, but I consider 18mm as on the absolute maximum edge of WA and it's closest focus is only 15" which is approx. 1:6....not very close to 1:1 which most judge as macro.
    This is a good all around lens to start with, but you'll soon need the extreme ends of true WA and macro.
    Karl
  4. It’s not a real WA lens or real macro but its somewhere in the middle between this two areas, It’s a good lens for fish portraits and semi WA.
    For real macro, you will have to use the 60 mm or the 105 mm lens.
    Edited by Arnon_Ayal
