Inon strobe with Sea&Sea 4 pin sync cord
Started by LyN ·
  1. I am planning tu buy the new Z240 strobe for Inon, but as today, I have a Matthias Heinrichs Digital Adapter with a Sea&Sea 4 pin port. <_<
    As the 5-pin Sea&Sea sync cord N can be used to connect Inon strobes to Nikonos ports (just as with Sea&Sea strobes) I was wondering if a Sea&Sea sync cord S (4 pin) could be used to connect the strobe to a Sea&Sea port. :P
    I already know that the S cable can be phisically connected to the strobe, but I don't know if the strobe will work with this configuration. :blink:
    Does anyone know anithing about it? :o
  2. HI
    Firstly, I You will need the Sea & Sea cord N to connect this strobe to you camera, The Sea & Sea 4 pin port is not Compatible with the 5 pins standard nikonos bulkhead.
    If your using a Sea & Sea 4 pin i suspect that you have previously used the YS60 or Ys50 with you TTL converter.
    Sorry to say, but i think you will need a New Digital Adapter 5 pin Nikonos style.
    regards
    craig
    better off trying Christain Weirkamp at HW for more information
  3. Firstly, I You will need the Sea & Sea cord N to connect this strobe to you camera, The Sea & Sea 4 pin port is not Compatible with the 5 pins standard nikonos bulkhead.
    Craig, if I am not wrong, the Sea&Sea cord S has a 5 pin connector for the strobe head and a 4 pin connector to connect to the camera, as Sea&Sea DUO strobes can use both, the N cord or the S cord, depending on the port of the housing/camera/adapter.
    So I think I may physically connect the Sea & Sea S cable to the strobe (by the 5 pin end of the cord) and to the S Adapter (by using the 4 pin end of the cord).
    But what I do not know is if the circuitry on the Inons is compatible with a Sea & Sea port on the host. I think THIS is the issue.
  4. Well, I have been reading around and asking some questions to Inon, and I think I may have the answer. I post it here because I think it may be useful to someone, who knows.
    It seems that the Inons circuitry is not of the DUO kind, which means it is only prepared to understand a real Nikonos TTL signal. There are some differences between the signals from a Nikonos or a Sea&Sea port and the Inons are not prepared to be connected to Sea&Sea ports, although physically the connection is possible.
    I have also found that it is possible to build and adapter to convert a Sea&Sea signal to Nikonos, and I think that Mike Finger (Mike Dive) knows how to do it. In fact I am waiting an answer from him to confirm he can build an ad hoc solution for that issue!
    If there is some interest, I will post here the final answer. ;)
  5. Hi LyN ,
    you will get an direct answer soon ...... the first here :
    The strobe will work also with the Sea&Sea Motormarine 4 pole synccable caus the
    Trigger , Quench and Ground pinns are the same. But there is a problem with the TTL converter getting it´s energy out of the missing Ready line and I do not know if the Trigger line of the Inon strobes is strong enough to serve too ...... I cannot test right now cause my last stock is sold today ... waiting for new D2000w.
    The YS60 and the YS50 are strong enough ........ to serve the Digitaladapter , and the TTL-C3 converter ( the TTL-IR converter is out ) also in the S version.
    But notice the INON strobe will not work with the Motormarine II and the EX
    Michael
  6. you will get an direct answer soon ...... the first here :
    Then it's clear. There is too much risk involved in trying the Inon with the Sea&Sea 4 pin cord.
    But I have buddies using Z220s with 5-pin DA-IRs without problems, so I guess in this setup it works. As I also own a YS60TTL/S and a DA-IR-S, the right solution will be the T connector from N & S to S, to be able to connect the Sea&Sea and the Inon to the DA. Is that right? I will wait for your news! :o
