IKELITE Housing
Started by rodriguezfelix ·
IKELITE Housing
  1. Can somebody post a picture of how came the shutter spring on an Ikelite housing Nikon D50, D70, D70´s or maybe Canon 20D or 30D assuming are the same... I don´t want to touch it... but I feel maybe a little twist on it can put a little more pressure on the shutter lever and make it more precise...
    Edited by rodriguezfelix
  2. Work around: put the AF on the AE-L/AF-L button and the shutterlever don't have to be precise.
    Very useful here in my cold country where you always have to wear thich gloves underwater.
  3. I just want to add a little more tension on it, but i need a picture of where the spring pass thru, and where the shutter lever must place... If somebody can post a picture of the inside part of the housing where the shutter lever goes, maybe I try to figure how to add a little more tension... TX.
