Nexus - Woody Dio's on Sea & Sea CM port
Started by craig nelson ·
  1. Hi
    I'm looking to get a hold of a Nexus wet lens for my Sea & Sea compact macro port s (32). any what one using one and what size have you found works.
    My ports external O/D is 102mm,
    do you think the plastic skirt on the 100mm version will adapt to 102mm, is it flexible enough.
    i know they do a 110mm. that will work , but i gota packout my port to allow use.
    Knowledge please
    craig
  2. You can probably make the 100mm work. If its really too tight heat the skirt in hot water (might want to remove the lens first) to help it stretch over the port. The skirts are made from port covers - 102mm is not a standard size & probably not available. Does S&S provide a vinyl port cover? If so, can you cut out the center to accommodate the wet lens?
    Edited by jcclink
  3. Hi,
    I have both S&S compact port & Nexus 100mm Diopter and will try and let you know later today.
    Happy Easter for everyone !
    Sam
    Edited by shchae
  4. its fine I used it on my SnS housing. When you put on the dioptre you use a twisting motion, a push and a turn like those tablet bottles. I suppose I should say to twist in the same direction as you would putting the port on but to be honest I dont remember ever doing it myself cos its natural for a right hander.
  5. Yes, you can use.
    Sam
  6. Great thanks sam.
    I'll get the 100mm version then.
    best wishes
    craig
