Aquatica D200 Control ?
Started by Ryan ·
  1. Nevermind... Apparently I offended someone.
    Edited by Ryan
  2. On my D2x Aquatica housing there is a small “coil†spring located slightly to the left of the vertical shaft to the camera control wheel. It fits between the plastic rectangular gear support structure and the housing. It can be difficult to see. I found it is best to look at an angle from the front of the housing through the lens port opening to get a good look at it. I would assume this control structure would be used in most of their housings so it may be applicable to the D200 housing.
    I will try to post a photo of the control wheel structure on the D2x housing, tomorrow, if time permits for comparison purposes.
  3. Here is shot of the offending spring.
  4. delete
    Edited by Ryan
