Coolpix 3200 worth a $155 housing?
Started by bpevans ·
  1. I have a Nikon Coolpix 3200 laying around and throughly tired of with my old 35mm point-n-shoot housing as the backscatter and orange glow in every photo is more frustrating than the effort to take it on a trip.
    Is my Coolpix 3200 worth getting a $155 housing or should I just pony up real money later for nicer camera & housing?
    I leave for Bonaire in a week and am thinking I'll give the coolpix a try for a season since I have it on-hand and the SD memory it uses is super cheap.
  2. Sorry for the delayed reply.
    It is worth the cost if you just want a housing. That will get you some nice macro shots and head & shoulders portraits. If you want a real system, then I would go for a more capable camera. The Fantasea housings are nice but don't give full control over all the functions.
    Just about every housing has a tripod screw at the bottom. You would use a base plate to attach a strobe.
  3. Thanks for the response. I've decided to pass on that idea.
    The coolpix 3200 is an aging camera with only ISO200 sensitivity so I couldn't see dropping $340 on a housing and Sunpack G-Flash both of which I probably wouldn't use very long.
    I'm lurking through a lot of old threads now and plan to buy a better setup after this Bonaire trip when i'm not so pressed for time. Currently toying with the idea of a second hand D100 setup or perhaps a better p&s setup. A lot of my local diving is dark, low-viz water (10fsw normally but up to 60fsw+ ).
