First DSLR lens/port combo
Started by stevewlkr ·
  1. Have been following the recent threads about lens choices but as one of those taking the plunge into DSLR my intial investment will be limited to probably one lens/port setup.
    (I am decided on the D200 but not decided on a housing yet - too much choice!)
    Maybe I am being unrealistic but i was hoping that I would be able to put together something that was workeable for the next twelve months or so then I can build on the intial investment as finance allows.
    Eventually I will probably aim for the 10mm and 105mm options but at the moment I would be concerned that 12 months of w.a. only or macro only would be frustrating.
    There do seem to be some mid-range zoom lense options but what are the benefits /drawbacks of zoom lenses? Are they potentialy an expensive mistake.
    Any help/suggestions greatly appreciated ?
  2. If you want to be conservative get the 60mm and a kenko TC 2X instead 105, that give you nice portraits and nice macro. If you want to take a chance with new zoom lenses (i did it..) get Sigma 17-70mm macro wich give you 1:2.3 of magnification, good low light AF and doesn´t need a diopter to focus behind a dome...
    Edited by rodriguezfelix
  3. Check out this recent thread:
    If you Had to Pick Just 3 Lenses...
    This should tell you all you need to know about the conventional wisdom on the relative importance of lenses underwater.
    FWIW I would get the 60mm macro and the Tokina 12-24mm first. Both are inexpensive and will get you most shots. I'd get the 10.5mm and 105mm when you can.
    Edited by UWphotoNewbie
  4. I think he meant Tokina 12-24. Tamron makes an 11-18.
    The Tokina is better.
  5. Yes. Sorry.
