only leaving fire pin on hotshoe connector
Started by 3@5 ·
  • 11Posts
  • 11Replies
  1. james i am trying to pick up on something you said in another thread:
    The Inon strobes work well with Canon. I used 2 Z220's with my 1DmkII. I removed the pins in the housing hotshoe, leaving only the center or "fire" pin
    i am trying to figure out why did you do that? i have used my z220 connected with all the pins, and have not seen any concern with it, but then again i may have missed something :)
    is this something i should be considering?
    thanks for your help
    /paul
  2. Hi Paul,
    Some cameras act wonky when the TTL and ready signal pin are left connected. I don't know if the 1DmkII is one of them, but if you're not using TTL, then I see no reason to leave the pins connected.
  3. when you say removed the pins, do you mean 'remove' ? can they go back in? or do you just cover them somehow ?
  4. It depends on the housing.
  5. thanks for that james ..
    thinking about this, then maybe the i did see some strange behaviour when trying a d2000w.
    for some reason the camera switched off and would not restart until i removed the battery and put it back in again; i think i have by mistake left the camera on s-ttl mode. something to investigate.
    ok this begs the next question: how easy is it to remove (and put back in again) the seacam pins?
    /paul
  6. Hi Paul,
    Luiz uploaded an article about how to remove pins from the hotshoe in Subal housings.
    For Seacam, you can literally pull the pins out w/ your fingernail or tweezers.
    HTH
  7. thanks for the info james
    now will i let my 2 left hands loose on something like that :) ?
    /paul
  8. Hello Guys
    My D70 does go "doo Lally" with all 5 pins connected. i just simply use electrical insulation tape to cover the pins.
    the bouns of doing this on my D70 is
    The Camera now does not think that a flash is connected "but it is only via FIRE pin" so i can use shutter speeds outside X-SYNC
    not sure how Canons work when only fire pin is connected, i presume the same if the camera is not being told that a flash is connected.
    regards
    Craig
  9. Funnily enough, my D100 doesn't like the Inon strobes, but my D1X doesn't mind them at all.
    With the former, I have to tape the front right-hand pin to get the camera to work (otherwise, it won't even let me take a shot, and shows a blinking red strobe led inside the viewfinder), but with the latter, there's no issue at all with all pins connected.
    Both cameras are housed in Secam housings, and I used the same sync cords for both. Go figure...
  10. not sure how Canons work when only fire pin is connected, i presume the same if the camera is not being told that a flash is connected.
    That is correct, Craig. The camera doesn't know there is a strobe connected. Perfect!
