Aquatica 90 Housing
Started by nordic ·
Aquatica 90 Housing
  1. Hello
    Will this housing work with current ports ?
    And will the databack window on the rear part do that the housing can't be used down to 80-90m ?
    Jan
    Edited by nordic
  2. Hi Jan
    This Aquatica N90 housing will work with current bayonet style Aquatica ports- currently the 8" dome port is the wide angle standard and the flat port is the base for macro.
    This housing with the back plate was rated to 100 meters.
    If you need additional info or advice- please contact me offline
    Mauricio Handler
    Aquatica Technical Field Advisor
    mauricio@handlerphoto.com
