best flash "calibration" technique?
Started by gwitek ·
  1. I have spent about 30 min trying to do my homework here before posting but come back empty handed. I need some aiming please.
    I am shooting a D70 + Aquatica D70 + dual YS-120s. My first (and most recent) trip out was also my first trip w/o TTL in many years. I am committed to learn to shoot manual but I am struggling a bit. I got some decent shots but only through what feels like brute trial-and-error. I am lookiing for a pointer to an actual process or methodology to "calibrate" or "dial in" a manual stobe distances and power settings. I have seen it referred to but not seen the actual steps laid out or a link thereto.
    TIA
    Greg
  2. You can use the guide number of your strobe as a rough place to start from. I think the YS-120 has a GN of about 32fsw (someone please confirm this). So if you're shooting F16, your strobes should be about 2 feet from your subject to achieve proper exposure. At F8, the distance would be 4feet, and generally speaking, the correct distance will be GN/Aperture
    To be sure you have achieved proper exposure, you can check the histogram (e.g. no spike on the right means no gross over-exposure), and adjust based on that.
  3. Hi,
    I have both D-70 & 2x YS120 Duo & I only use this combination for wide angle pic (1m+ arm + full power) as it is too strong for macro & has no way to properly adjust the power for D-70 - ISO 200 default camera.
    Sam
