lenses for sharking
Started by pmooney ·
  • 10Posts
  • 10Replies
lenses for sharking
  1. WONDERING WHO USES WHAT WHEN THEY ARE SWIMMING AROUND WITH THE STRIPEY SHARKS
    I'm thinking 14mm rectalinear , 16mm F/E , 17 -35 up close and personal and may be 50 1.4 for portraits
    What do you think
    :P:D:D
  2. I use the 17-55 and like it a lot. If it is a shark feeding place and they get really close the 10.5 will be fun.
    Luiz
  3. I've use 12-24 and found it a little too wide. 17-55 sounds just about perfect ($$$ :P )
  4. Sooo, you say the stripies..
    You going to Bahamas?
    Your selection sounds good to me
  5. Here are some examples of my choices:
    10.5mm:
    12-24mm:
    17-35mm:
    The lens I really regret not taking was the 16mm. This is the lens that Jim Abernethy uses (well he uses a 15mm on his Canon D60) almost all the time. Similar coverage to the 12-24mm but nicer corners.
  6. What camera? That might make a difference in what people would recommend. But I like Alex's idea of showing you some actual results rather than just telling you, so here are a few of mine (using a full-frame camera):
    16-35mm @ 16mm
    24mm (to compare same subject as one of Alex's)
    And here are two with a 15mmFE
  7. I work on ShearWater, and would make the same recommendation that Alex did - the 15mm on a cropped camera is a great shark lens. I don't like the distortion of the 10-22. I use the 17-40 on a full frame and it works extremely well - the 15mm works well on a full frame also, but it depends on how close you're willing to get :-)
  8. Hey Brian.... wanna change jobs for a while?
  9. I think that Brian makes a good point. The sharks are big - and I am happy to admit that it took me plenty of dives to start using the wider lenses! It takes a while to build up to getting real close. A 17-35mm range lens is a good choice for the early dives.
  10. I have to agree that the 10-22mm was too wide for many of the situations we had on Shearwater, even on a 20D (which is not full frame) But I was happy with the results when we got some of our closer interactions! If I were to do it again I think I would take a 17-40mm as well.
