Urgent help! Best dome to use...
Started by Mattkk ·
  1. Hi All - I am dire need of some advice as I have zero time to get in the water and do some testing. Has anyone used a 10.5mm with a Nexus D2X and if so, what dome are they using? I am leaving Tuesday am for a trip and have come up short with kit - will my old 9" dome work alright with a suitable extension ring?
    Many many thanks if anyone can advise!
    Matt
    www.scubazoo.com
  2. Hey Matt
    i don't use a Nexus but a 9" should be fine, i doubt you need the extension ring either as teh 10.5 is such a short lens.
    I use the 10.5 in my Aquatica with no extension and an 8" port
  3. Apparently the new Nexus mini fisheye dome is a nice one.
    But your old one shoudl be great. On all other housings I have seen - the same port as you used to use on film for the 16mm is fine.
