Sea&sea Compact dome for nikon 10,5mm?
Started by V_kids ·
  1. I have Nikon 10,5mm and Nikon 12-24mm.
    I want to buy only 1 dome for both of these lens.
    I prefere to buy the compact dome because of the dimension/size of this dome (compare to the fisheye dome) is quite small.
    However, im not sure if i can use the nikon 10,5mm with this compact dome.
    Can anyone please give me some advise?
    Thank you in advance
    Andree ;)
  2. The 10.5mm matches with the compact domeport very well. It is the 12-24mm that I used to have problem with. You will definitely need a diopter if you use the compact domeport with 12-24mm and I was never quite satisfied with the result. I almost bought the big fisheye domeport for the 12-24mm but then I switched to Subal when D2X came out so I never tried Sea and Sea big dome.
  3. Mr. ssra30
    thx you for your answer.
    However, i still dont really understand... why you never satisfied with the result?
    is it because of the vigneting? or focusing problem?? please explain it.
    And why do i need a diopter if i want to use the compact dome port with nikon 12-24?
    Sorry to troble you Mr. Ssra30
  4. When I was using D70 with Sea and Sea housing, I found that without a diopter, using the compact domeport with the extension ring that Sea and Sea recommended, I could not focus on anything closer than about a meter or so away. To get closer, I tried 2+ and 4+ diopter and never like the result very much, lots of distortion around the peripheral.
