Quicktime codec for HDV & DVD burning?
Started by globaldiver ·
  1. I have edited a HDV project and try to burn it to a DVD in iDVD. What codec should I use as I export the video to Quicktime so I can retain as much of the quality as possible from the HD format to DV?
    If I use the HD codec iDVD crops the video to 4:3 since it seems to not register the format...
    Any good suggestions?
    Sincerely
    Anders
  2. Hopefully you're using a recent version of iDVD. If so, when you create a new project, set the aspect ratio to widescreen 16:9 (File>New).
    Then don't encode your HDV movie at all before bringing it into iDVD--iDVD will do the encoding for you. There are good instructions in the iDVD Help Menu (Help>iDVD Help).
    If you're working with an older version of iDVD, upgrade (it's cheap). I think you'll need at least iLife05, but iLife06 is preferable, to work with HDV. Hope this helps.
  3. Thanks, it works now...
    I did not realize that iDVD encoded the material itself. Thought I had to do it before I exported it to the program. Live and learn... :D
    I use the most recent version of Final Cut Express and iDVD, and a 17" Mac Book Pro. With 2 Gig of RAM it works really well for editing HDV. I can however see that I in a near future may consider FC Studio Pro.
    Thanks for your replies.
    Sincerely
    Anders
